Slack notification not firing (intermittent issue)
1761 3
Y_K
7 - App Architect
7 - App Architect
Does anyone also have similar issues - slack notification not firing?
If you configure slack notification to send notification based on views, View A -> Channel A, View B -> Channel B. Sometimes only one channel receives the update, sometimes both. When it’s not sending notifications I mean nothing at all – not even ‘skipped records’ message.
3 Replies 3
Kim_Prisk
Are you using private Slack channels?
No. A public channel for the team.
Inga_Orlova
Does Slack not post to private channels?
