Small charity looking for help setting up Airtable from scratch
1471 2
sarah_mountcast
School Food Matters is a small campaigning and food education charity based in SW London looking for help to move us from spreadsheets to a database. We’re not looking for a complicated CRM rather a central record of all our 10,000-20,000 relationships gathered over the past 10 years. An efficient and user-friendly search capability is key. AirTable seems to fit the bill so if you have experience working with charities with limited budgets and setting up databases, please get in touch.
Thanks
Andrew_Johnson1
8 - Airtable Astronomer
Hi Sarah,
I have worked on some pretty similar projects in the past and would be glad to help you out on this.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
Hi Andrew
Apologies for the slow response, we have a member of staff off sick at the moment and we are doing year end so it’s a bit busy!
I have some questions if that’s OK.
Have you worked with charities before, if so are you able to provide any references?
What rate do you charge?
Are you based in the UK / London?
I am attaching some use cases that we have put together that may help you to understand what we need the database for.
Thanks
Sarah
