[Solved] Dynamic buttonAsync labels and values?
1914 2
Chris_Guthrie
7 - App Architect
7 - App Architect
Can the buttonAsync be created dynamically?
I have an array of Order Numbers called filteredOrderNames. Can each value of the array serve as the button label?
let selectedOrder = await input.buttonsAsync(
'Select Order Group from List below',
    {label: filteredOrdersNames, value: filteredOrders}
18 - Pluto
18 - Pluto
Yes, this can be done using the map method on the filteredOrdersNames array. Here’s a test I just ran:
let filteredOrdersNames = ["One", "Two", "Three", "Four", "Five", "Six"];
let filteredOrders = [1, 2, 3, 4, 5, 6]
    "Select order group from list below",
    filteredOrdersNames.map(item => {return {label: item, value: filteredOrders[filteredOrdersNames.indexOf(item)]}})
output.text("Selected Order: " + selectedOrder)
Output:
Screen Shot 2020-09-07 at 9.25.25 PM
18 - Pluto
18 - Pluto
Output:
This is brilliant! Thanks so much. It works perfectly.
