Some Concatenations having "" and others not
1868 5
James_Rhoads
Hello All!
I’m using a formula to concatenate different dates an area was worked on as the record ID. In one tab I have all the offices and all of the associated data with them, and in the other I have a submissions page that’s linked to the office page. My problem is some of them concatenate as “AreaName” - Date and others are AreaName - Date. I have attached some screenshots for a visual.
Thank you for your help!
AirtableCommunityP3
AirtableCommunityP2
AirtableCommunityP1
18 - Pluto
18 - Pluto
That means that you have hidden characters somewhere within the area name for those records. So you’ll need to manually cleanup those area names.
5 Replies 5
18 - Pluto
18 - Pluto
Thank you! I had to end up resetting all the names.
For future reference, you could have also used TRIM({Area}) to remove extra spaces at the start and end of the text.
I believe TRIM() will only work for spaces. Last time a client of mine had this problem with quotation marks, there were lots of invisible characters of some sort (that weren’t considered spaces) that were causing this problem.
Ben_Watts
I get the same issue using the following
IF({_Uniclass System}=BLANK(),{Uniclass Products},{_Uniclass System}) the fields its looking at don’t have “” in them
