Sort not sorting as expected
984 2
Greg_Witkamp
I’m expecting this group of records to be sorted in the opposite direction. It doesn’t seem like it’s sorting by the entire string since “.5” is before “.25” and “.75” is after “.25”
Is there a way to correct this?
18 - Pluto
18 - Pluto
Sometime Airtable does funny things when sorting strings with numbers. My guess is that Airtable is sorting “5”, “25”, and “75”. If you change the “0.5” to be “0.50”, does it sort properly?
18 - Pluto
18 - Pluto
Greg_Witkamp
You know what Kuovonne, you’re a smart one. That did the trick.
