76285members
167125posts
Community Activity
Avoid duplicates in automation that creates new records
Hi AirTable community! I have a problem that I can't, for the life of me, find a solution to.I have an Event table that includes a linked column for Personnel attending the event. I also have a separate table where I have profiles for each person for...
  • 54 Views
  • 1 replies
  • 0 kudos
Automation to create Link to an existing table
I am struggling with the last stage of an automation and keep getting a message that it's received invalid inputs but I can't figure out what I'm doing wrong. I'm a Literary Agent and have a Titles table, an Authors table and an Editors Table.When I'...
  • 69 Views
  • 1 kudos
Automation and linked tables advice - Events management
I'm trying to create a solution for managing events and event attendance.I have 3 tables: Contacts, Events, Attendance.In the Contacts table, an Event is manually linked via a linked field (the Contact can have multiple Events in here, sometimes adde...
  • 97 Views
  • 0 kudos
Resolved! Automation - Send email failes when no assignee entered
Hello everyone, I have the following problem: I have an Airtable automation that informs the assignee of a project when some fields change. Now we often have the case that there is no assignee yet but someone edits one of these fields. Then the autom...
  • 73 Views
  • 0 kudos
Move record to new section when record is updated
Hi folks! I have been stuck on an automation for a few days now  I have two tables: "Tasks" and "Topics".I used the "Topics" table to add a layer to my "Tasks" table. Individual records in "Tasks" are nested under the appropriate "Topics" section.The...
  • 132 Views
  • 0 kudos
Can't Get Nested IF AND Statements to Work
Hello Airtable community!I inherited a pretty robust Airtable system from a predecessor and have been working to revamp it, but my formula skills are not as good as the person who came before me, and I've been struggling to get IF AND statements to w...
  • 257 Views
  • 0 kudos
Resolved! Removing NaN where + and - values can exist
Hi there! I am trying to remove NaN values from a formula field where both positive and negative values exist. This is in an effort to clean up two extensions: One chart indicating the number of each value's occurrence and one number where I am tryin...
  • 228 Views
  • 0 kudos
Resolved! switch or nested IF for conditional commission calculation
Hi,I'm trying to create a table to track income and the records feed from different tables using automations which are assigned a deal type as they're created. If they're type A the commission is 15% of the payment amount, if they're type B the commi...
  • 512 Views
  • 8 replies
  • 0 kudos
Announcements
WIP: Airtable Community
NOTE: This blog was updated on 2/26/25 Hey Airtable Community  You might have noticed a little something different with the community, and we wanted to share a little bit about what we’ve been worki...
Announcements
Airtable Top Contributors | January 2025
Hey Airtable Community, It’s the month of  LOVE  so it’s only right to shower some love and gratitude on our top contributors today! If one of these members has helped you out, show them some apprec...
Announcements
Airtable Universe Projects
Office Hours Command Center
See how Wayfair has optimized the internal and external flow of their Office Hours system using Airtable.
by Jensen Fitzgerald
Highspot Marketing Launch Base
Highspot uses this Interface to track cross-departmental actions for large marketing launches associated with product releases.
by Kristine Agnelli
UX Process & Project Planning
An inside look at how Expedia's Flights UX team uses Airtable to organize and automate tracking projects, tasks, sprints, and workload.
by Expedia Flights
Airtable Formula Playground
This base is a way to reference and test every Airtable formula.
by Jason Schulke
