Split string into columns
5373 1
Mateias_Andrei
Hello :slightly_smiling_face:
I have a list of urls in a column.
domain.com/cars
domain.com/cars#bestdeal
domain.com/cars#top10
I want to split the url at the “#” and create 1 more column. So the new table would look something like this:
domain.com/cars
domain.com/cars bestdeal
domain.com/cars top10
Is this possible in airtable?
Excell version:
Merge or split cells in a table
You can merge two or more cells in the same row or column of a table. You can merge several cells to create a heading that spans several columns.
You can use some functions to get those portions, doing some math:
  • LEN to know the length of the string
  • FIND to know in with character the # is (a number)
  • SUBSTITUTE to “delete” the extra parts (substitute with ‘’)
There are some threads in the forum to inspire you: https://community.airtable.com/search?q=split%20string
