Squarespace Product Block Data
Topic Labels: ImportingExporting
1020 2
Megan_Smith1
How can I automatically create a new row of data in airtable from my squarespace account with the product data, custom product form, data, and customer data?
Probably the easiest & quickest way to do this would be to use a low-code/no-code automation tool such as Integromat.
As far as I know, Integromat is the only automation tool that has deep Squarespace integration:
p.s. I am an Integromat Expert+ Partner and Airtable consultant. If you have a budget for your project and you’d like to hire someone to help you set this up, please feel free to contact me through my website:
Thanks Scott. I had been using Zapier - but it doesn’t have the functionality I need. I’ll take a look at Integromat.
