"Step pending..." when running a script
3034 7
edgaras
I am trying to run a script on a record update, but when I look in the Run History, all the trials end up in the “In progress… Step pending…” state.
Did anyone ran into a similar problem?
The script I am using is a simple fetch to Integromat Webhook. And it works when I test it separately with the test button.
7 Replies 7
Divyaansh_Anuj
Facing a similar issue with all automation triggered scripts getting stuck at “In Progress…” state. Here’s how it looks: image
Any ideas how to resolve this?
Airtable is currently having trouble running scripts.
https://status.airtable.com/
jdavis
This is happening to me.  It doesn't look like there are any issues currently with airtable according to kuovonne's link.
This is happening on trigger from record creation, webhook, etc.  The automation just hangs on this step endlessly.
HansThisen
Happening to me too. Already submitted a support ticket.
Run Script Stuck in "In Progress..." - Worked like 1000 times. Now it's just freezing every time...
I think there's an issue on the backend sometimes.  Previously the issue just resolved itself fine.  I'm currently getting unspecific errors with automations.  I have a feeling there's just something wrong on their end at the moment which will eventually get resolved.
Cool thanks for the heads up
