SUBSTITUTE Formula - Not removing apostrophe
999 2
Sparkn_AI
Hey there, looking to create a simple slug and for some reason the apostrophe isn’t being removed.
formula
Example Title: Zoom Fatigue is real, so let’s deal with it.
So make lowercase, remove apostrophes remove commas, remove full stops and replace spaces with dashes (etc) is what I’m after.
LOWER(
SUBSTITUTE(
	SUBSTITUTE(
		SUBSTITUTE(
			SUBSTITUTE(
				{Name}, "'",""
I cannot fathom why the apostrophe is not being removed. I’m missing something easy… ideas?
Martin_Kopischk
7 - App Architect
7 - App Architect
Hard to tell because of the resolution of your screenshot, but might that apostrophe be a typographically correct one (), not the ASCII single quote (') your formula is replacing? You can cover that case and get rid of other nested SUBSTITUTEs by using REGEX_REPLACE. For instance, this:
LOWER(
  REGEX_REPLACE(
    REGEX_REPLACE(Name, "['’´,.]+", ""),
    "\s+", "-"
will substitute a hyphen for whitespace and remove dots, commas and common apostrophe variants.
Martin_Kopischk
7 - App Architect
7 - App Architect
LOWER(
  REGEX_REPLACE(
    "\s+", "-"
My dude! Thank you. I now know about REGEX-REPLACE. :pray:
