Sum for Duration Column?
357 0
Diana_Dizon
Hi there! Sorry if this questions has already been asked but I was wondering if there was a way to use the summary dropdown for a duration column. I have a column for video lengths grouped by series, I’m looking for a way to find the sum of each series but when I go to the summary dropdown at the top of the table, I’m not met with any options that enable that. I do have durations set as “h:mm:ss” but I’m unsure if AirTable has a way of summarizing time. Any suggestions are helpful, thanks!
0 Replies 0
