Switch between Bases and Workspaces similar to Views
Would be nice to be able to quickly switch between Bases and Workspaces without having to go back to Home. Similar to how you can switch between Views for a Table.
Welcome to the community, @mrlau! :smiley: This can be done using the base switcher hotkey. On the Mac, it’s Command-K, so I’m guessing it’ll be Ctrl-K if you’re on Windows. That hotkey works whether you’re inside a base, or on the home page. Start typing the name of any base from any workspace, and you’ll be shown a list of matching bases. Use the arrow keys to pick the one you want, and Enter to select it. I use this constantly, and it’s a huge time saver!
Problem solved for now then!
