Thank you @kuovonne for your reply. I was reading this post about another SWITCH() case and understood that formulas can be inside SWITCH pattern.
What I am trying to do is: if “pattern” strings are found among listed services, then a complex formula works differently with this field and other fields to generate a long formalized text. This text contents vary depending on contents of {Services} and that is why different output should be produced in the text string.
I have done it with nested IF(), but SWITCH seems to be more elegant and easier for modification approach - when new {Services} are added to the multiple select (life goes on), nested IFs are very difficult to modify, while SWITCH is much easier to update.
Thanks again @kuovonne.
Unfortunately formula field reference does not say anything about “pattern” or “result” possibility to be formulas. We learn it experimental way
Yes, the formula field reference doesn’t cover everything. If you feel that this is important information to include in the documentation, I suggest that you contact support with your suggestion. I find support to be very helpful in updating documentation. (I do not work for Airtable.)
