Synchronize external data (SQL/CSV) with Airtable
1379 1
Dvd_Txr
Is it possible to synchronize our database (SQL or CSV) with Airtable?
We have a database (SQL) of vendors with different information such as name, turnover, number of products etc… We want when we add/modify/delete a vendor, product or something else to our database, that it automatically adds the new data to Airtable.
Do you have a solution for me ? API ? Synchronize in real time ?
We can generate a CSV several times a day with our data. In order to retrieve the data from this CSV to update it in Airtable.
Thank you,
David
Hi, and welcome to the community.
These two ideas are incongruent.
I think you need to look at this.
