Table will not load
761 1
Richard_Foxwort
7 - App Architect
7 - App Architect
My base has a particular table that’s large - it has about 35,000 records and about 13GB of attachments and my base in total has just over 38,000 records.
I know this is getting pretty big in Airtable terms, but its well under the 50,000 records and 20GB attachments limits for my Pro plan.
The other smaller tables in my base load and continue to work fine.
This problem table shows the ‘Loading view’ spinner, but then a very unhelpful error popup appears:
Screen Shot 2021-12-05 at 6.58.10 pm
I know I need to migrate away from Airtable since I’ll overun the 50k record limit within next few months, but I thought I had that much time up my sleeve to figure out the migration…
Now my base does not function at all which is a business critical issue.
I’ve contacted Airtable support and send Console info, not sure if anything else I can do for now…
Any advice on how to proceed much appreciated.
JN_tp
You should try using Firefox or Safari as a first step as I’ve found Chrome uses more resources.
