62936members
146401posts
Community Activity
Airtable to Google calendar automation
This automation has brought me to my knees, please help.I'm trying to create a google calendar event for a session booked from a start time to end time. The automation fails because it's unable to parse datetime: " "This is my flow:1. I enter the dat...
  • 3 Views
  • 0 kudos
Using a decimal/valuta from a Lookup field in a formula
Hey guys,I'm having trouble using a valuta like € 1.333,61 in a formula. It's being recalled from another table using a Lookup field. I've tried adding a new formula column/field and reformatting it first, before using it in a formula, but without an...
  • 14 Views
  • 0 kudos
RVB by 5 - Automation Enthusiast
Design bases all linked to a single key
HiI am a curriculum coordinator in higher education and have multiple bases/tables/forms that contain/gather information about course units in the curriculum. All information always relates to a course unit, e.g. Business Economics. All the informati...
  • 25 Views
  • 1 replies
  • 0 kudos
Designing A Judging System for Science Fair
Hi Everyone! I'm trying to design a judging system for a science fair styled event but I'm wondering if there's an easy way to do the judging assignment through airtable or if I can do it through Excel then transfer to airtable. Right now I have thre...
  • 31 Views
  • 1 kudos
🚀 Unlock the Power of Digital Solutions for Your Business! 🚀
Your one-stop destination for supercharging your business with cutting-edge digital SaaS services! Here's what makes us stand out with over 300+ projects completed: Tailored Solutions for SMBs, Startups, and Entrepreneurs:We understand the unique nee...
  • 27 Views
  • 0 kudos
INVALID_PERMISSIONS_OR_MODEL_NOT_FOUND
I have my personal access token with all the scopes, but when I try to create a new entry the  api is returning this error:          "type": "INVALID_PERMISSIONS_OR_MODEL_NOT_FOUND",        "message": "Invalid permissions, or the requested model was ...
  • 45 Views
  • 0 kudos
How do I send the offset request?
I've seen this question, but not the type of answer I'm hoping for. A CURL example is a great for me to translate the request. Similar to the CURL examples in the docs for List Records, it looks like I should be able to request records 101-200 using ...
  • 42 Views
  • 0 kudos
ids by 5 - Automation Enthusiast
Upgrading issue
Hi, it's been more than two weeks since I raised this issue. My issue in upgrading the base to team Plan is not resolved. I am nearing the project submission deadline. Kindly help. @airtable
  • 35 Views
  • 1 replies
  • 0 kudos
Lookup Field filtering/limiting number of items shown
What is the proposed idea/solution?User would like to limit the items show to unique values only.I.e. when a lookup field references a multi-select/single-select field from a linked record. Suppose there is 20 linked records, each of which has a mult...
  • 93 Views
  • 7 replies
  • 0 kudos
Ability to change status on base for users who are not paid users
Hi. I'm creating a base that would be populated by the form. There'll be some fields that will be handled inside the base by paid users. I've created an automation that would send an email to a departement once the status changes. People would get a ...
  • 73 Views
  • 0 kudos
Resolved! Linking records on a form
Hi I was wondering if anyone would kindly help. I am creating a form from a grid view I have created. One of my fields in the grid view allows me to link with a master data base and pull all required info through using added lookups. This doesn't see...
  • 71 Views
  • 1 replies
  • 0 kudos
add +100 on each new row
Hey,Something super basic to do in any excel, python script etc. but how to get in in Airtable?I want to create some kind of ID for each customer. First customer has number 900100, and each new one (this is a child table) should get the number +100, ...
  • 57 Views
  • 0 kudos
Generate random hex color code
Hi Community!I would like generate with a formula a random hex color code for each new record in a database. How can I do that?Thank you for your help!Stefan
  • 49 Views
  • 0 kudos
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
Introducing Pivot Tables in Interfaces
Hi there! I’m Rosalind – a product marketing manager at Airtable focused on helping teams build powerful, custom applications that make work more efficient. I’m eager to share that we have just launch...
Announcements
