63440members
147473posts
Community Activity
Updating information about employee attendance in another table
Hi everyone! I'm trying to build monthly employee attendance with NFC tag. Basically when you "scan" nfc tag with your phone, it open up AT Form for submitting your entry or leave (start in the morning, start of the break, end of the break and end of...
  • 21 Views
  • 1 replies
  • 0 kudos
Create Bar Chart from Date Fields
Dear AT Community!I'm collecting arrival and departure dates for an event setup period from workers. They can register through a form. In my base now I have two date fields with an arrival and a departure date for each worker. The setup period spans ...
  • 30 Views
  • 1 replies
  • 0 kudos
Complicated lookup field's Type causes formula to fail
I have two tables Experiments and Readings.Each experiment is linked to two or more reading records. Each reading has a DateTime field, and some readings such as pH and temperature. The pH and temperature readings are number fields.I want to use the ...
  • 39 Views
  • 0 kudos
Downloading a PDF file from an Extension
Hey,I have an extension in Airtable that creates a file for each record within a Table. Is it possible to download each file as a pdf and populate a file field in the same Airtable record? Each file generated by the extension doesn't have a unique UR...
  • 49 Views
  • 1 replies
  • 0 kudos
Color records with a single select lookup field
What is the proposed idea/solution?When using a linked record and pulling over a single select field by using a lookup, it would be very useful to be able to color records with it. At the moment, it doesn't give you that option.For example, let's ima...
  • 23 Views
  • 0 kudos
Resolved! Phone Number to Plain Text Formula
Hello, I think I need a help of Airtable community even though there is built in AI helper in the formula field. Here is what I am trying to do and have no success for some unknown for me reason. I'm creating an automation that with the click of the ...
  • 52 Views
  • 0 kudos
bedjik by 6 - Interface Innovator
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work. We understand the importance of protecting sensitive patient data and maintaining compliance with industry regulatio...
  • 220 Views
  • 1 kudos
Announcements
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
