Toggle checkbox with Script
Topic Labels: Extensions
1463 2
Damian1
I was wondering if there’s any script that allow me to check/ uncheck the box? I can only do one but I want to make a toggle checkbox.
This is the script for check only
let table = base.getTable("Product List");
let record = await input.recordAsync("Interest", table);
let recordId = record.id;
await table.updateRecordAsync(recordId, {
    "Interest" : true,
Tom_Keysers
Try getting the current value of that record’s checkbox field and just inverse it using !.
Something like this (untested code):
    "Interest" : ! record.getCellValue("Interest"),
Tom_Keysers
Thank u so much. It works perfectly.
