Tracker view connection
Topic Labels: Views
491 0
Sascha
is it possible to connect the tracker view to another table in the same base?
so that it collects the status infos from table 1 (grid view) and sorts and shows them in table 2 (tracker view)
many thanks
0 Replies 0
