Treat cells with 0 and empty value differently
823 1
Divaksh_Jain
Cell value 0 is blank
Cell value 0.00 is blank
Cell value empty is also blank
How to treat cell with 0 value and empty cells differently?
All the following forumas are returning result for both the {Buy} cells that has zero value and the {Buy} cells that are empty.
I want result only for the cells that has 0 or more value not the cells that has empty values.
IF(AND(IF({Buy} >= -1, TRUE(), FALSE()),{Sell}), (Sell-Buy)*Lot*Qty)
IF(AND(IF(NOT({Buy} = 0), TRUE(), FALSE()),{Sell}), (Sell-Buy)*Lot*Qty)
IF(AND(IF({Buy} = BLANK(),  FALSE(), TRUE()),{Sell}), (Sell-Buy)*Lot*Qty)
18 - Pluto
18 - Pluto
To test if a numeric field has a value including zero, concatenate it with an empty string …
IF({Buy} & "", "Buy has a value", "Buy is blank")
18 - Pluto
18 - Pluto
