Two way calendar sync on integromat possible?
1283 3
Alson
https://support.airtable.com/hc/en-us/articles/215275748-Using-Zapier-to-integrate-Airtable-with-Goo... similar to this is a two way calendar sync on integromat possible? Like in zapier? From Airtable to google calendar?
3 Replies 3
Alson
Has anyone tried this? Thanks.
I haven’t tried this specific setup, but I did help a client set up a system in Integromat to sync between Airtable and Google Contacts, so my guess is that doing something similar with Google Calendar should be possible.
Thanks for the response.
