Typecast does not work when set to True, Airtable Python Wrapper
Working with the Airtable Python Wrapper to batch insert records that have multiple field types, including “select” fields. even when Typecast is enabled, I get the below error:
Unprocessable Entity for url: https://api.airtable.com/v0/appPdjdf8ska/rtt (Decoded URL) [Error: {‘type’: ‘INVALID_MULTIPLE_CHOICE_OPTIONS’, ‘message’: ‘Insufficient permissions to create new select option ““ja””’}]
The code below works when all fields are text fields, so i’m not sure what I need to change?
airtable_conn.batch_insert(data, typecast=True)
