Typeform connection doesn't work
Topic Labels: API
576 0
Info_Arca_Prope
Hello Community,
I was able to connect Typeform to Airtable, however when I choose a “Picture Choice” field in Typeform, my table doesn’t recognise the field and I cannot connect the Typeform field to my column in Airtable even when I make a ‘multiple select’ column out of it.
Does anyone know how to connect my picture choices from Typeform to multiple select columns?
Much appreciated,
Bruno
0 Replies 0
