63742members
148071posts
Community Activity
Page Designer - Various Pages for different table values
I have a table that has a column, lets call it Food. I want to create datasheets for the drop down options I have set up for the food column and I am looking for a way to cater a page set up based off what drop down option is selected. For example: T...
  • 16 Views
  • 0 kudos
Workday function showing weekends
I am trying to have a due date automatically calculated, but don't want weekends or holidays included. I am using the WORKDAY function, but still getting weekends. Workback from is the date to begin working on each task and Workback is the number of ...
  • 18 Views
  • 0 kudos
Splitting Client Names into Two Rows
I am building a base for client follow up. When our clients are a couple, they are entered on the same row in our main table. I have the client name column as a look up field in our Client Birthday table, so it pulls the name from our main table. How...
  • 28 Views
  • 0 kudos
Syncing schema / table structure between bases
I have a schema, which I would like to implement for 3 similar businesses.  Is it possible to have the same base template, and have the schema synchronised between ALL 3 bases?  That is, if for example I add a new table, it is also added on the other...
  • 24 Views
  • 0 kudos
Published Form missing Helper Text
I have published a form and used the helper text as a description for some fields. When I preview the form within my account, it looks great. When I try to use incognito mode or a different account to view the form, the helper text is missing. Can so...
Screenshot 2024-04-25 at 9.55.43 AM.png Screenshot 2024-04-25 at 9.55.35 AM.png
  • 49 Views
  • 0 kudos
Automation to populate field from different table
Hello, I am looking to build automation.I have 2 tables: Task and Sub Task (both are linked). If a subtask is created under the task record, then the project selected on the task should be auto-populated in the subtask project field related to the sp...
  • 48 Views
  • 0 kudos
Resolved! Aritable listRecords API not returning fields data
HiI am trying to use below code (Google Apps Script) to get data from Airtable. The fetch request succeeds but the fields are returned as text [Object]. I am not able to see actual data. However the request works from other HTTP clients like Bruno.I ...
  • 69 Views
  • 0 kudos
Sri1 by 6 - Interface Innovator
Manual entry for Formula field.
I have a payment tracking table. It has fields that are Original Cost, Variable Cost, and Fields for each month(Jan - Dec): Formula Field). The original cost is linked from another table. If the user does not provide any value to Variable cost, The o...
  • 46 Views
  • 1 replies
  • 0 kudos
How to see detailed charges / billing
I gave access to a couple of people who are actually my clients to a database I designed for them.I want to know what is the exact charge for those licenses / users so I can charge them for those expenses.
  • 41 Views
  • 1 replies
  • 0 kudos
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
