Use IF to return results with many conditions
882 2
Lucas_Vieira
Hi guys
I’m trying to use the formula IF to return some values. This is my example:
I have 4 conditions, wich are the number of words that a text must have:
  • 500 words
  • 1000 words
  • 2000 words
  • 2500 words
And to each one I have a specific value
  • To 500 return 30
  • To 1000 return 45
  • To 2000 return 55
  • T0 2500 return 70
I tried to use the formula that I use in Google Sheets: =IF({number of words}=500;30;IF({number of words}=1000;45;IF({number of words}=2000;55)))
I tried to use this way but it returns error. How could I use this formula in my case?
Zollie
10 - Mercury
10 - Mercury
The Airtable syntax is a little different, but they’re nearly identical.
IF({number of words}=500,30,IF({number of words}=1000,45,IF({number of words}=2000,55)))
Here’s that code refactored:
SWITCH(LEN({words}),500,30,1000,45,2000,55)
Lucas_Vieira
Thanks, Zollie.
It worked! :slightly_smiling_face:
