Use one template of tasks for each project - how?
Topic Labels: Base design
624 0
User_User
I would like to achieve one template with tasks that is applied for all projects,so when a task is changed, added, deleted, renamed, reordered - the same thing should happen with the task inside a project. The only thing different per each project is the status, the money, the time etc etc.
In this short video you’ll get better what I want to achieve:
Thanks very much in advance!
I wasted so much time today trying to use synced data and I couldn’t figure out how to do this.
Help is much appreciated!
0 Replies 0
