Use outcome in formula field in another formula field
5187 20
Onur
maybe I its to obvious and I don’t get it - but how can I work with the outcome of a formula field?
Every time I build formulas with which I want to “work further” with the outcome of another formula field there is no output (blank).
Any idea how to make that possible?
Thanks in advance
Onur
20 Replies 20
Thank you once again - this support from the community is awesome!
This really helped me out.
I will mark this as solution here.
