Users submitting their own posts
Topic Labels: Base design
1107 1
Rahul_Madhugiri
I created a form with airtable because I wanted my users to be able to submit their own posts which include a title, description, and an image and I wanted it stored in the spreadsheet I made with airtable. Is there a way for me to connect my form with Thunkable so my users can submit their posts through my app?
If a Thunkable form allows you to send submitted form data from your app to Airtable by communicating with Airtable’s API, then yes.
