Using a doc in field for job applications
772 0
Sam_Soon
I tried to search for this, and I found things that were similar but not exactly what I was looking for. AIA if I simply missed something.
I (and the team with which I work) use several Airtable bases to manage volunteer work/projects. We are currently looking to add to our volunteer team, but we need someone with a great eye for detail. We wanted to use a field to show a document (that we review quite often and then need to correct and return to the submitter) and then ask the person which errors they can spot.
Is there a way we can do this without having to put each part of the document in a separate field and ask “Is there an error here? If so, what is it?”
TIA!
0 Replies 0
