Using a formula calculated date and DATETIME_FORMAT
870 2
Anne_Gonzalez
I’m trying to use DATETIME_FORMAT to format a date calculated by a formula to the way I want it to be displayed. I have to use DATETIME_FORMAT rather than the settings button because I’m inserting it into an automated email, which defaults to YYYY-MM-DD format instead of the settings.
It seems like this should be possible but I keep getting an error. Here’s my current formula: DATETIME_FORMAT((DATEADD(TODAY(),14, “days”), ‘DD-MM-YYYY’)
The center formula DATEADD(TODAY(),14, “days”) works properly on its own, so I know it’s something about adding the formatting piece.
Is it possible to do this in one formula?
18 - Pluto
18 - Pluto
I’m not at my computer right now, but I think that should work. I would check to make sure that you’re using straight quotes, not stylized quotes.
18 - Pluto
18 - Pluto
Anne_Gonzalez
Thanks! I guess that was it. I entered it again, in the same way I swear I’ve entered it previously, but it works now.
Here’s the final product:
DATETIME_FORMAT(DATEADD(TODAY(),14, “days”), “MM-DD-YYYY”)
