Using Airtable for SEO tags
Topic Labels: API
1022 1
Shaun_Hornsby
I did a quick search and couldnt find what i am looking for so i apologize if this has been asked and answered already. I have a Word Press site using the Airpress plugin to pull data from one of my bases. Everything is working as it should but i am trying to figure how to input the airpress shortcodes into the header of my virtual pages for metatags. Has anyone been able to do this using Airpress? If not, is it possible, using the API, to build a custom template that will use airtable data for metatags?
Airpress shortcodes work great in the body and so far it has done everything i need it to do except this.
shanti_rubens1
Hi, I have the same issue I am trying to solve. I hired a Wordpress developer but he didn’t manage to complete the task. However, he tells me it is possible. Has anyone found a solution for this?
