Using an emoji in an IF formula
I want to create an IF formula so that if a a calculation > 0, then the calculated positive % + “:white_check_mark:” should populate, but if the calculated formula is < 0, then the calculated negative % + “:stop_sign:” should populate. When I do write this formula, the correct number and emoji shows up, but the calculated value has many decimal places.
How can I change the formula so that no decimal places will appear (e.g. 35%)?
Formula:
(1-SUM({Apr 2020 Staffing 1},{Apr 2020 Staffing 2},{Apr 2020 Staffing 3}))>0,
:white_check_mark:” & " " & (1-SUM({Apr 2020 Staffing 1},{Apr 2020 Staffing 2},{Apr 2020 Staffing 3}))*100 & “%”,
:stop_sign:” & " " & (1-SUM({Apr 2020 Staffing 1},{Apr 2020 Staffing 2},{Apr 2020 Staffing 3}))*100 & “%”)
I actually solved it by using round() formula.
