Using an IF statement to cap given number in a field
592 1
Darren_DuHadawa
I’m trying to link multiple fields together and cap the number depending on another field’s selection.
For example:
Currently I have this formula working as intended in the a field:
{X field} / WORKDAY_DIFF({Y Date}, {Z DATE})
I want to add a quantifier on top of that will determine the number it puts out.
So, if field A=B, cap the number at 2
If field A=C, cap the number at 1.
Try the following:
MIN(
  IF({Field A} = "B", 2, 1),
  ({X field} / WORKDAY_DIFF({Y Date}, {Z DATE}))
That will take your original calculation and insert it if its less than either 1 or 2 (depending on Field A}'s value). If it its higher than that number, your cap number will be shown instead.
