Using Automations to add attachment to existing record using Form view
Topic Labels: Automations
2042 2
Steven_May
I’m an Airtable novice. We have Table with existing records. I’d like to create a Form view that allows users to add an attachment to an existing record. Someone from Airtable’s helpdesk said it may be possible by creating an Automation, but I can’t figure out how to do it. Any advice?
Thanks in advance for your support!
Steve
Mark_Barnes
You’d need to create a separate table, and then use Automations to update the existing table when a new record is created in the new table. Attachments are slightly harder than other fields to update, but there are instructions here: Use automation to copy attachment to new record
Hello, thank you for your response! I’ve tried to follow the instructions but cannot make the automation work. As I mentioned, I am a newbie and don’t really know anything about coding. I’ll keep looking/asking around. Thanks again for your help.
