Hi all,
Have you used this functionality before? If so, how did you implement it? This is just not working for me. https://support.airtable.com/hc/en-us/articles/115007655568-Using-forms-to-edit-tables-with-Zapier?auth_token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhY2NvdW50X2lkIjo2MTc1MzcsInVzZXJfaWQiOjQwMTY2NTcwNzM3NCwidGlja2V0X2lkIjozMTkwNCwiZGVmbGVjdGlvbl9pZCI6MzYwMzM0OTgwNDU0LCJhcnRpY2xlcyI6WzIzNDk4MjUwOCwzNjAwMzk3ODEzOTQsMTE1MDA3NjU1NTY4XSwidG9rZW4iOm51bGwsImV4cCI6MTU4MjMwNDc3MX0.m3wt8MOI9MzS-pnGge3fhHhhN13nBAhi-IUF5ezhjfM&solved=0#zapdoes
Here’s what I am trying to do: I need to be able to update just one cell (don’t know what it’s called in the Airtable world… so, will refer to it as cell for now) when the user fills a form. This form has three sections. Two are pre-filled and the third is updated by user.
Currently, any user updates are creating a brand new record. This is a HUGE problem. Each of my records has a QR code. If a new record is created after each user update, that would mean creating a new QR code for each record, i.e., each user will have more than one QR code. That is a near death scenario for my project. (Not being dramatic at all.)
So, I need to update just one cell when the user updates the form. The rest of the record and the table needs to stay the same.
I have been trying the multi-step zap in the link above. It’s not working.
Anybody out there who could share how they solved this problem?
Many many thanks,
Airtable Newbie!
