Using if statement to detect empty "Long text" field
How do I test for an empty Message field when it’s a “Long text” type?
This code does not work…
let strReplyStatus = '';
if (rsReply.getCellValue('Message') === '') {
    strReplyStatus = 'Empty';
if (rsReply.getCellValue('Message') == '') {
This code works…
if (rsReply.getCellValue('Message') === null) {
Alternatively:
if(rs.Reply.getCellValue('Message').length===0){
//do whatever
Or, if you want to get cute:
if(!rs.Reply.getCellValueAsString('Message').length>0){
//do whatever
Checking for null values is a pretty yolo thing to do in JavaScript AFAIK, and just going for the length check is usually better in terms of performance.
