I’ve got an opportunity tracker base that’s logging potential project opportunities from five different countries.
I’m trying to set up a column that takes those individual budgets and converts them all to USD so that I can see our global pipeline in one currency.
To do this, I’m assuming I need to set up a formula that cross references each project budget against the city of origin for that project and only does currency conversion if necessary.
Basically I want to do something along the lines of
If {City of Origin} = “New York” or “Los Angeles”, then just reprint {Budget}
If {City of Origin} = “London”, then just multiply {Budget} * 1.3
If {City of Origin} = “Paris”, then just multiply {Budget} * 1.4
etc etc
But I can’t figure out the syntax.
Would anyone be willing to help?
Also, can anyone recommend best practice for referring to currency conversion multipliers in Airtable that might be simpler than hard-coding the numbers right into the formula?
Thanks so much in advance for any help you can offer!
And for the currency, are you suggesting that if I have six different currency conversions, that I should add six different columns and autopopulate each one somehow with that rate?
The question regarding the currency multiplier is wherever or not you will want this same number to change the old entries or just the new entries. i.e.: you have an entry that is 2 months old, do you want it to use the new number or stay on the old number?
In all cases, you will need to add a new Field called Currency Multiplier. Depending on you answer above you can either make it an automatic task using a formula or do it manually. You will use this field in the formula above from @Noamsay
