Using IF to look up field value, and return another field value
3378 4
John_Anthony
First post and couldn’t find the answer. I’m trying to create a nested IF.
Field A, single select as choice 1, 2, or 3.
Field B, is a Date
Field C, is a Date
Field D, is a Date
I’d like to the formula to check the value of Field A.
If it’s 1, return date from B,
If it’s 2, return date from C
If it’s 3, return date from D
4 Replies 4
AlliAlosa
10 - Mercury
10 - Mercury
You’ll want to use a formula like…
SWITCH({Field A}, “1”, {Field B}, “2”, {Field C}, “3”, {Field D})
You’ll also probably want to use DATETIME_FORMAT() to get your dates formatted the way you want. :slightly_smiling_face:
Thanks. I keep getting errors. Here’s the exact fields.
Field is called Renewal Date. Formula below
Based off the formula, I want it to populate the date from the correct field.
“Renewal Type” is a single select. Options are P&C, Benefits, LFS.
So if P&C is selected, use the date in the “P&C RD” field.
SWITCH({Renewal Type}, “P&C”, {P&C RD}, “Benefits”, {B RD}, “LFS”, {LFS RD})
What am I missing?
Thanks!!
Your formatting looks correct, so perhaps you are just running into an issue with smart quotes being used in your formula, instead of dumb quotes – this can happen if you copy/pasted a formula out of the forums that has smart quotes in it (like @AlliAlosa’s does).
To remedy that, try clearing your formula entirely, and typing it in by hand into the formula field editor.
It could be the quotes as @Jeremy_Oglesby mentioned, but I am all of a sudden (as in within the last hour or so) returning errors on ALL of my fields that incorporate the SWITCH() function… I just started a new thread on this and am about to contact support!
