Using Integromat to change view filter settings
Topic Labels: Integrations
1219 2
YourFriend
Can I use integromat to change the filter settings of one particular view?
I use different views to trigger certain integromat scenarios and it would be great to be able to trigger or turn off scenarios via integromat changing the filer settings of an individual view.
Thank you for your wisdom, friends.
18 - Pluto
18 - Pluto
No, you can’t change filter settings via the API. Filters must be manually changed by the user within the Airtable interface.
18 - Pluto
18 - Pluto
Thx Scott
Appreciate the swift response.
