Using integromat to identify the same info in two different bases
Topic Labels: API
726 1
Curtis_Budka
Have a database of almost 500 pieces of heavy equipment with multiple manufacturers- each having a different style serial number. Each of the manufacturers put our updates by serial number (for software, parts failure issues, saftey issues, etc). Each update document has its own unique code and a list of serial numbers that it applies to.
Here’s what I’ve started: I take the s/n list from each document and put it into a spreadsheet and upload it via the .csv block, so each record created represents a single update that applies to that machine. This is done in its own base because I don’t want to use up my record limit, just two update documents meant 700 new records.
So I am looking for a way to find the matching serial numbers one machine at a time in the new “imported file” base, and use that collection of info to link the machine in the machine table to the proper update in the update table.
Sorry if this is confusing.
Curtis_Budka
Hopefully these will help, customer and partial serial numbers blocked out because these are real machines and real customers.
