Using lookup value in a formula has a weird behavior
Topic Labels: Automations
392 0
Chadd_Dumagas
I am just baffled about using the value of the lookup field cannot be directly used in a formula
WEIRD SITUATION 1
When you use
{My Email To} << lookup field, with single value
LEN({My Email To}) return #ERROR
Solution 1
LEN(CONCATENATE({My Email To}))
Solution 2
LEN({My Email To}&"")
Freaking amaaaaaaazziiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiing riiiiiiiiiiiiiiiiiiiiiiiiiiiiiiight? :clown_face:
is this the simplest solution? do you have any other solution?
WEIRD SITUATION 2
When you use
{Name} with values (Name1, Name2), << linked field, with multiple values
{My Email To} with values (Email 1, Email2) << lookup field, values shows with space and comma
{My Email To}&"" return values (Email 1Email2) << formula field without space and comma!!!
why does the lookup field value change? why can’t they just make that in-line value a literal flat string?
0 Replies 0
