Using script block to get page designer link into record
Topic Labels: Extensions
1993 4
remy_konings
Hi there,
Is there a way to use the Scripting Block to get a download url of the “print” button from the Page Designer block into a record?
I’m looking for a way to get the Page Designer pdf into a record. I’m only using the mobile app but I would love to download a pdf from the page designer block from a record.
4 Replies 4
Alex_Evers
I am looking into the same thing! A script export records from a page designer block and put them into an attachment feild in a record.
PeterMengO
Me too! Or be able to export a select goup to individual PNG’s into the associated attachment field on their record.
Broghan_Zwack
Any luck with this? It would be hugely helpful for a project I’m working on.
Fernando_C_B
Es una de las funciones que más necesitamos, el poder imprimir un bloque desde la aplicación.
Exactamente he ido investigando si pudiera encontrar un ENLACE URL que pueda obtener y convertirlo a PNG.
La cuestión es qué el bloque de Page designer es un Editor , y lo que estaría bien es que hubiese un Page designer sólo de VISUALIZACIÓN.
Creo que eso resolvería todo.
