Apr 19, 2017 11:06 AM
I’ve been searching the forums and the help topics for two days. I’m sure the information is here, and, at this point, I’m just too frustrated to find it. I’m asking you to please not simply link me to the information but to also provide the information in a reply. TIA.
My team is migrating from to-do app to AirTable for a variety of reasons, but one of the (many) ways we are using AirTable is as an extremely glorified to-do list. One base that we use has a “Deadline” field. Another field lists various records as either a “Round” or a “Deadline” (the field is called “Type”).
We are looking for a formula that will give us this: if the “deadline” field is before today, then the “type” field will automatically be changed from “rounds” to “deadline” – dates that are equal to or greater than today would remain as “rounds” (Background: When a record is entered, it is automatically entered as "rounds.)
Every time I’ve tried formulas such as those I would use in Excel or similar to examples I’ve found here, I got error messages essentially telling me that “today” was not a recognised category.
Again, TIA.
Apr 19, 2017 12:05 PM
Hi Sam
Something like this should do it:
IF(Date >= TODAY(), “Rounds”, “Deadline”)
and as seen in the formula window:
Hope this helps?
Julian
Apr 19, 2017 12:19 PM
Thank you SO much!
When I looked at what you wrote, I said to myself, “I TRIED that!!!” but I clearly did since that worked. Like I said in my OP, I think I just got so inside the problem that I frustrated myself too much instead of being able to take a step back (not to take anything away from your help!)
I really appreciate your assistance!
Apr 19, 2017 12:25 PM
No problem - we’ve all been there!
Jul 30, 2018 01:02 AM
Hi Sam
Wondering if you could perhaps help as I am struggling with a similar issue.
I want to write and IF Function thats says
IF actual start date is greater than the planned start date return “Delayed Start”
AND IF actual start date is blank and today’s date is after the planned start date then return “Delayed Start”
Can this be done?
Jul 30, 2018 01:47 AM
I think you meant “OR IF actual start date is blank…”
I haven’t tested it, but I think this should work:
OR(
IS_AFTER(
{Actual Start Date},
{Planned Start Date}
AND(
NOT(
{Actual Start Date}
IS_AFTER(
TODAY(),
'Delayed Start'
Jul 30, 2018 02:05 AM
Not sure i am inputting it correctly. Tried copying and pasting directly but it doesnt seem to work.
Jul 30, 2018 02:09 AM
Somehow, it appears the single quote after 'Delayed Start'
has become a ‘curly quote’ rather than a straight quote; Airtable formulas require the latter. Try re-typing that one character from your keyboard.
Jul 30, 2018 02:20 AM
That odd character seems to be the problem — but there’s another issue with the original formula I provided: For some reason, it returns #ERROR
whenever {Actual Start Date}
is blank. I couldn’t get it to work after a couple of attempts, so I rewrote the whole algorithm into a more ungainly one that does work. (This version also doesn’t return #ERROR
as its default response until a date is entered.)
IS_AFTER(
'Delayed Start'
IS_AFTER(
TODAY(),
'Delayed Start'
still no luck. I had to play with the spacing a bit so that might be the issue
Jul 30, 2018 02:26 AM
No, both the first and second formulas I provided are valid formulas; the first just has that annoying #ERROR!
problem I can’t clear.
Your second example seems to suggest your field names don’t match what I provided — you’ll have to change them to match your naming convention. (You’ll notice you did fix the first issue: Airtable now sees it as a valid formula and attempts to parse it, at which point it discovers it doesn’t understand the field names.)
Jul 30, 2018 02:38 AM
This seems to work:
IF(OR({Actual Start Date}>{Planned Start Date},AND({Actual Start Date} = BLANK(),{Planned Start Date}<TODAY())),‘Delayed Start’,BLANK())
Jul 30, 2018 02:42 AM
Genius - Thank You.
Is there a way to update a field based on an input to another?
I am trying to update my planned start field based on the value input into the actual end field for a previous task…
Jul 30, 2018 03:07 AM
Hi Douglas
This is probably not so easy - formula fields operate within a single record and I am assuming that your looking to calculate a value based on a value in a different record in the same table?
If this is the case, then it’s likely that you won’t be able to do it just in Airtable but would need something external like Zapier or Integromat - the latter is my favourite despite being a bit clunky when building logic for Airtable at the moment.
Data wise, you would probably need to create a link from your task table to itself and then link one record to another. Normally this would mean you could use Lookup fields and formulae to do what you need but when Self Joined, you can’t do this - hence the logic needing to be external.
Julian
Jul 30, 2018 06:34 AM
Thanks for your help, will give that a go.
