Vega Lite filtering and layering issues
988 0
Richard_Wilcock
I am using airtable to track and manage activities in a plan.
the relevant table has a baseline date field, a latest planned date field and an actual date field.
Not every task has each date completed
I want to plot cumulative progress (count the number of tasks due to be complete, or complete) over time.
I am using Vega Lite to plot cumulative graphs.
Within Vega-Lite I am using filters to remove the records with no dates, then use window and count operators to generate cumulative values.
I can plot each graph independently, but if I try to layer, vconcat or hconcat the three graphs together than the filtering either cuts off the baseline fields or creates an incorrect jump at the start of the planned/actual dates as null dates are passed to Vega Lite as 01-01-1970.
Looking for ideas please!
transform and encoding script below:
“transform”:[
“filter”: {
“field”: “Baseline Date”,
“gt”: 0
“sort”: [{“field”: “Baseline Date”}],
“window”: [{“op”: “count”, “field”: “count”, “as”: “Cumulative Baseline”}],
“frame”: [null, 0]
“filter”: {
“field”: “Latest Planned Date”,
“gt”: 0
“sort”: [{“field”: “Latest Planned Date”}],
“window”: [{“op”: “count”, “field”: “count”, “as”: “Cumulative Planned”}],
“frame”: [null, 0]
“sort”: [{“field”: “Actual Date”}],
“window”: [{“op”: “count”, “field”: “count”, “as”: “Cumulative Actual”}],
“frame”: [null, 0]
"hconcat": [
    "mark": {"type": "line", "color": "grey"},
    "encoding":{
      "y": {
        "field": "Cumulative Baseline",
        "type": "quantitative"
      "x": {
        "type":"temporal",
        "field":"Baseline Date",
        "title": "Date"
    "mark": {"type": "line", "color": "maroon"},
    "encoding":{
      "y": {
        "field": "Cumulative Planned",
      "x": {
        "type":"temporal",
        "field":"Latest Planned Date",
        "title": "Date"
    "mark": {"type": "line", "stroke": "lightblue", "point": true},
    "encoding":{
      "y": {
        "field": "Cumulative Actual",
        "x": {
        "type":"temporal",
        "field":"Actual Decom Date"
0 Replies 0
