Version Control for Automation Scripts?
Topic Labels: Automations
1174 2
Tommy_C
Hi All,
Can anyone offer any guidance on how to version control scripts used in Automations?
Currently, we create a duplicate base, run some automated tests on that base. If the tests pass, we copy the updated scripts over to the production base. It’s not ideal, so curious if anyone else has found a better solution.
All the best,
Tommy.
Marko_Petrovic
7 - App Architect
7 - App Architect
That is something that interest me also, not just for scripts but for all parts of Airtable base.
We basically do the same thing like you now, and I am afraid there is no some better way to do things natively.
Damian_Naglak
Anyone found solution for this? I am wondering how this appealing feature could be created but i cannot find a way to export/import or modify scripts by API.
