Very simple automation does't work!
Topic Labels: Automations
501 1
Jerome_CHABAUD
I’m a beginner with Airtable.
My first test is to use the automation with run script action
I created a automation on the trigger 'When a record is created ’ like this
2021-09-01 08_19_16-Ligue1_ Match - Airtable
But i don’t see the message in the console when i create a new record
I have 2 errors messages :
2021-09-01 08_18_08-Ligue1_ Match - Airtable
Have you a idea about this issue ? (I have a Pro plan)
Hi @Jerome_CHABAUD - you don’t see console.log in the browser dev tools as you would for a wep app. If the script window is closed then you can’t see any log output in the automation window, but if the script window is open you can see it in the output panel:
Screenshot 2021-09-02 at 17.23.22
