View by specific SQL :)
Topic Labels: Views
780 3
Daniel_Roziecki
I need to create a view similar to this SQL question:
select name, max(date) from xxx group by name;
I have no idea how I can do this with airtable.
Any help?
3 Replies 3
You can’t create a view like that, but you might be able to use this SQL app to display the matching results:
Eric_Goldman1
7 - App Architect
7 - App Architect
Thanks for the shout out @ScottWorld :pray:
@Daniel_Roziecki – we built the SQL Console app. Would love to make sure you get set up properly. Feel free to send us a quick DM or email me directly if you need anything: eric@syncinc.so
Thanks, this is a great tool, but I need some smart views for automations, and sadly this is not a solution for me.
Airtable is great, but sometimes I need a lot of creativity to do some stuff :slightly_smiling_face:
