Web Clipper Problem
Topic Labels: Extensions
955 2
Ron_Williams
Anyone else that is using web clipper not working? Im getting "The clip action could not be loaded
Please verify the app settings and try again." Seems to have started this morning when it changed form apps to extensions.
Alex_Lerma1
Yes, me too. I am having the same issue.
WebClipper 06232022
Yes, this seems to be a widespread problem right now amongst most or all customers. Be sure to send an email to support@airtable.com so they can work on fixing it.
