63724members
148039posts
Community Activity
Aritable listRecords API not returning fields data
HiI am trying to use below code (Google Apps Script) to get data from Airtable. The fetch request succeeds but the fields are returned as text [Object]. I am not able to see actual data. However the request works from other HTTP clients like Bruno.I ...
  • 8 Views
  • 0 kudos
Sri1 by 5 - Automation Enthusiast
Manual entry for Formula field.
I have a payment tracking table. It has fields that are Original Cost, Variable Cost, and Fields for each month(Jan - Dec): Formula Field). The original cost is linked from another table. If the user does not provide any value to Variable cost, The o...
  • 12 Views
  • 0 kudos
How to see detailed charges / billing
I gave access to a couple of people who are actually my clients to a database I designed for them.I want to know what is the exact charge for those licenses / users so I can charge them for those expenses.
  • 25 Views
  • 0 kudos
I need a formula for 2 decimal digits mixed with text
I'm new here so I do not know that many formula. I imported my tables from excel and I have it generate name of the product with product name + weight. However, I want the numbers that are generated in 2 digits format. And here is my current formula ...
  • 41 Views
  • 0 kudos
Forms: avoid entering an existing ID
I have created a form to create new Project records. Each project requires a unique ID which matches a particular format (XXXX-000).How can I make sure that no-one uses an existing unique ID when filling out the form? I really need to avoid duplicate...
  • 25 Views
  • 0 kudos
MrW by 4 - Data Explorer
Nested formula only partially working
Hello,I'm trying to create a mapping using IF and OR statement, in order to map a set of values for the 'Status' field to this new formula field.  This formula doesn't cause an errors, but it only partially works.  Does anyone know why this doesn't w...
  • 740 Views
  • 0 kudos
Hide/Show field or group based on logged in user
Is it possible to only show certain fields to certain users?For instance, if someone is logged in and has an email that ends in @whatever.com, we can mark that field only visible to those users.Any other suggestions would be welcomed!
  • 50 Views
  • 0 kudos
Formula within automation
Hi - I am trying to update a forecast in case the field hasn't been updated for over a month. The idea is that if there are no updates, the forecast would lower by 10%. It all looks great, until I have to "Update record", I pull the record ID (dynami...
  • 35 Views
  • 1 replies
  • 0 kudos
Help. Labeling Relationships in CRM
Does anyone have any ideas on how to label relationships in this CRM we are building? We have multiple relationships we want to label such as spouses, siblings, advisors, parent-child. We also want it to work in the inverse so it shows that Sally is ...
  • 35 Views
  • 1 replies
  • 0 kudos
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
Announcements
