Where do I get info about beta features?
Topic Labels: Extensions
4429 5
BenInDallas
7 - App Architect
7 - App Architect
I just started playing with the new Blocks feature and the new Page Designer. But really have no idea what either of them is capable of or even intended for. I can’t find any descriptions, instructions, tutorials, etc, anywhere on the Airtable website, in the app, or in this forum. How do I get help with these tools?
5 Replies 5
I’ll DM you some info to help you get started :slightly_smiling_face:
Would appreciate any info on block instructions as well especially chart page design and summary
Thanks
Zola
Page Designer sounds interesting :slightly_smiling_face:
Vernon_Fowler
7 - App Architect
7 - App Architect
I just implemented a Happiness tracking survey for Deakin Library Search and related tasks (much the same as Google did for Google Docs / Drive products - https://research.google.com/pubs/pub43221.html).
Data gets automagically pushed into Airtable.
Below is a timeline visualisation block of the responses from the first 23 hours of the survey deployment. There are 7 colours (single select field - hopefully this can be a calculated formula field in future :pray: ) representing the scale of overall satisfaction, from red and yellow - extremely and moderately dissatisfied, through to light blue and green - moderately and extremely satisfied.
This shows the frequency of evaluations over time, and the general sentiment towards Deakin Library Search. This looks useful for story telling and reporting with stakeholders, particularly if I filter the view to only show the promoters / detractors, or other criteria.
Hopefully we can embed blocks soon too. :pray:
Would also appreciate any block instructions! :slightly_smiling_face:
Thanks
Vegard.
